dltx 71 carb.
john deer bob 4
02-07-2007 11:17:28
have a dltx 71 carb that i have cleaned removed all drill plugs & cleaned getting air through all the holes new spay nozzle everthing looks right getting gas from tank into carb. but not to plugs ,,what am i doing wrong, oh new float set right.Thanks for any help....
Pappy
02-07-2007 18:14:59
 Re: dltx 71 carb. in reply to john deer bob 430, 02-07-2007 11:17:28
Be sure to check to see if your choke is actually closing when you pull the rod. Dltx71 has that spring mechanism and can be a little tricky.
Glen in TX
02-07-2007 12:40:11
Try pulling the intake loose also and see what happens. Then you'll know if you have air cleaner obstruction or just didn't get one of the passageways or bowl vent cleaned out well enough. Also check some carb tests at Pat's site under carb section.
Glen in TX
02-07-2007 12:18:07
Hopefully you got the right float for it and it's not rubbing anyplace on bowl as it's a differnt one on DLTX 71,72 & 73 and for those and DLTX 67 they recommended 3/8" below the top of bowl casting for fuel level and 1/2" on all others. Initial idle settings for JD A would be 1 1/2- 1 3/4 open for idle needle and 3/4 - 1 turn open for load needle. Those are initial settings only and will vary with your engine and climate and be less turns open on gasoline.
todd nelson
02-07-2007 11:53:49
what are your load and idle settings at?
john deer bob 430
02-07-2007 12:26:55
 Re: dltx 71 carb. in reply to todd nelson, 02-07-2007 11:53:49
thanks for the replys have 1 3/4 turns on the nettles & float set at 3/8 is this enough or to much on the float just at a loss as to why not getting gas to plugs???
