48 JD B wide-front value
Marc ON
02-06-2007 05:16:31
Hi folks, I'm a Farmall guy looking at getting my first green tractor and I've spotted a nice 48 B with factory wide front, shutters, original 6v genny and Powr-Trol. I've tried to do comparisons with similar B models being sold on this site and others but they're pretty much all narrow fronts. What value does an original wide-front add to the typical selling price of these tractors? $500? $1000? And are they rare enough that I should jump on it right away?
Thanks in advance for your advice!
Marc
Ten-Twenty
02-06-2007 08:00:39
 Re: 48 JD B wide-front value in reply to Marc ON, 02-06-2007 05:16:31
Marc ON,
It depends. If the tractor is actually a "BW". i.e it has the long rear axles, 42" rear rubber, and a tall spindle factory wide front, then it is uncommon enough to warrant some special consideration. If it is a regular row crop Model "B" with the short spindle factory wide front, it is still somewhat uncommon in that it has a two-piece front pedestal and a factory wide front that by itself might be worth at least $800.00 (assuming it is in good shape).
Marc ON
02-06-2007 19:39:45
 Re: 48 JD B wide-front value in reply to Ten-Twenty, 02-06-2007 08:00:39
third party image
Ten-Twenty, here"s a pic of the B, is this what you mean by a short spindle?
Mike M
02-06-2007 05:41:42
I'd say they are rare. At least in my area.But I don't know if they bring much more ? I often wondered why we never seen any ,until I drove one. You can't turn them sharp enough to turn around. I really like those Late B's very good power and traction from a little machine.JD 2 cyl. are sure a whole different breed than those Farmalls everything is going to be laid out differently.
