MW pistons
BLinWMi
02-05-2007 21:49:42
Have a 46 A, looking for ways to get a few more horses. Have the engine apart to replace frozen block, wondering what a person would gain by using M&W pistons compared to the factory cast ones. I know one of the best ways to gain horse is to increase compression, just wondering what these pistons would do.
DSK
02-06-2007 11:07:51
 Re: MW pistons in reply to BLinWMi, 02-05-2007 21:49:42
An M&W piston set will give you about a 6-8 HP increase over the original low compression cast pistons. I have a 41 A with .125 over M&W's and it dynos 36 HP, no other modifications. You could also use a JD high compression cast piston from a later A but these were available only in standard and .045 over. These yield about 2 horse less than the M&W's because they have about .8 point less compression,but in my opinion a more durable piston than the aluminum M&W. Little gained from standard bore to .125, so don't go any bigger than you have to. Most of the HP gain from the rebore kits are from increased compression.
