John Deere 630 power steering
John Emerson
02-05-2007 19:21:33
Help me! My 630 power steering pump makes a noisy vibration at a very narrow range between idle and fast idle. Absolutely no noise at slow or working speeds. Fluid levels are OK.
Suggestions?
machinery-man
02-06-2007 04:07:16
 Re: John Deere 630 power steering in reply to John Emerson, 02-05-2007 19:21:33
Sounds like your bearings are going out. Vibration probably occurring as your fan blade is required to increase rpm and resulting torque is vibrating pump. Really there"s not much you can do except you might be able to rebuild bearings only at this point or otherwise you might let it go till you need to buy a rebuilt pump. The bad bearings will likely take it"s toll on the pump gears. I suppose it could also be some built up pressure or dirty relief valve. Maybe you could flush and install new fuild prior to tear down and see if this corrects. Most of the time bad bearings will also produce a leak. My best imput from information provided. Good luck Chuck
