2 cyl. brakes
R50085623Animal
02-05-2007 16:53:23
How about those brakes on row crop tractors, what a pain in the butt! I have about 10 hrs. on one side.
RalphinWI
02-05-2007 21:23:44
 Re: 2 cyl. brakes in reply to R50085623Animal, 02-05-2007 16:53:23
When farmers in our area (hilly WI)started renting extra land after WWII, runty kids were taken threshing to drive the tractor while loading bundles. Even the smallest of us could hold a Deere on a hill, we could only reach one hand brake on a WC, the H Farmall had good brakes, but we had to slide our butts off the seat to reach them, the 9N was something else again. Even with standing on both brakes and threatening to pull the steering shaft out by its roots, one tried to get the tractor at an angle to the wagon, thereby bending the hammer straps on the wagon with the miserable excuse they used as a drawbar. Admittedly the smallest kids might have had trouble snapping the clutch on our A. When we bought the first tractor spreader, we went back to the John Deere dealer and also bought a drawbar designed and made by Deere for the 8N. In fact the Deere brakes were too good. They would hold without really locking them tight, and most farmers would sooner or later start out with them latched only realizing their error after they could smell them.
dds-inc
02-05-2007 18:55:30
sure, a real "pain in the neck" Try putting 500 bucks of disk brakes (just one side) on my stupid farmall 350 and 404. Also try putting brakes on an 8n Ford with 2 sets of weights and a tire loaded with calcium.
I'm going to say that pulling the drums off of any two cylinder tractor is a PIECE OF CAKE.
Chuck730DSE
02-05-2007 16:58:46
Which model are you working on? My 730D is a dream to put brakes on, easy to adjust, etc.
Keep in mind that with most other tractors, you are jacking it up, one side at a time, removing the wheel (heavy if it has fluid)
Animal
02-06-2007 08:14:17
 Re: 2 cyl. brakes in reply to Chuck730DSE, 02-05-2007 16:58:46
This old 70 had set forever, and the shoes were rusted to the drums, so bad if fact that it ruined 2 shoes after I got them apart. The pedal assembly was solid as so was the adjuster and the adjusting pins. You guys are right in the fact that if this tractor had been used every day the brakes would be a piece of cake.
Chuck730DSE
02-06-2007 08:22:23
 Re: 2 cyl. brakes in reply to Animal, 02-06-2007 08:14:17
Your favorite penetrating oil is your friend, as the brake shoes are going to be ruined anyway. A little "fire wrench" to those moving pieces will help too. Heat them slow, don't get them too hot, then let them cool. That typically will break them apart. Cannot use enough of that penetrating oil.
When you are putting it all back together, carefully apply anti seize to the moving parts like the adjusting screws. This will prevent problems in the future, even if it sits out for a while. Do not let it get on that drums or brake shoes.
