JD 1830 anybody ? ?
Dan C.
02-05-2007 10:51:56
My 1830 (219 diesel)needs a new clutch and starter ring gear.
Quite a bit of blow by - thus pressure coming out
of the crank case vent tube.
I also have quite a bit of water in my oil. With all that being said I am looking at a engine rebuild and clutch work. Has anybody had this done on their 219 engine and what was the cost ??
One of the JD service reps is currently going to provide me a quote (I am afraid of what that will be) but I would like to hear from others on here what it might have cost them ? ?
Also - does anybody know of a good JD mech in the Arkansas area I can contact ???
Thanks
DAN
DanC
06-16-2007 11:25:45
 Re: JD 1830 anybody ? ? in reply to Dan C., 02-05-2007 10:51:56
Well here is a late up date from when I first posted my water in oil problem.
I found some one local in the eastern part of Arkansas and this guy bleeds green. We rebuilt
the 219 engine and rebuilt the water pump all for
$1500.00. My tractor is a 75 model and the main
bearings were stamped 75 so this was the 1st total rebuild. Only one bearing showed any signs of wear. Found the water pump just about ready to throw the fan blade off - bearing gone. He remarked how well the inside look for being over
30 years old. Runs great hopefully it will be another 30 years of use before I need to do it again. The 219 is a great engine.
Tech 7
02-06-2007 07:29:05
depending on what the clutch needs you could spend $1000 right there. I can't remember the price of the job on the last 1830 I did but an "in frame" rebuild took about 40 hours. As far as what you could spend repairing vs.what you paid for the tractor Iam not sure you could replace it today with an equal machine for that money.... Bob
johns48jdb
02-06-2007 04:06:26
do they make a short block for that tractor? sounds like that would be cheaper than redoing yours.
Dan C.
02-05-2007 12:36:31
Holy Crap !! !
The JD service rep quoted me $6700 for a total
"complete" engine over haul, ring gear and clutch.
Thats pushing what I bought it for 8 years ago.
I need help!
buickanddeere
02-06-2007 11:01:20
 Re: JD 1830 anybody ? ? in reply to Dan C., 02-05-2007 12:36:31
Trade for a 5105 with M4WD. Putting $$$ into an old tractor just leaves you with an old tractor.
