jd 4010
123 farmer
02-05-2007 05:58:55
How exactly do the engine oil cooler on these 4010s and 4020s work. Is it cooled by antifreeze and water or cooled by somehting else. thanks
Glen in TX
02-05-2007 09:10:08
 Cooler pic in reply to 123 farmer, 02-05-2007 05:58:55
third party image
You can see it in parts catalog online. Depends on which tubes or hoses someone was thinking of. #27 is a oil line. #2 & #24 should be water lines.
Kent Petersen
02-05-2007 06:34:13
 Re: jd 4010 in reply to 123 farmer, 02-05-2007 05:58:55
Bob the water flows thru the tubes
not the oil Kent
Bob
02-05-2007 12:19:24
 Re: jd 4010 in reply to Kent Petersen, 02-05-2007 06:34:13
You're correct, Kent.
Thanks for the correction.
Bob
02-05-2007 06:04:23
It is a "tube and shell" heat exchanger.
Engine coolant surrounds a bundle of tubes, and engine oil flows through the tubes.
The coolant circulates with the rest of the coolant, by the action of the water pump.
