2130 load control seals followup questions
Charles Branch
02-04-2007 16:16:33
I posted a question earlier about the load control seals on my 2130 (the same as a 2030 I believe), and the responses give me the courage to try the repair. Some earlier posts discussed this job on other models, but I haven�t seen any details on the 2130, and the picture on the Boling site looks a little different from mine.. According to my tech manual, I should remove the rockshaft assembly. The manual also indicates that the 2130 already has O ring seals.
Questions:
1. Is there any reason to remove the rockshaft assembly other than to inspect or adjust the other parts?
2. If I do not remove the rockshaft assembly, will I have problems lining up the load control shaft when I re-assemble it?
3. Since the 2130 apparently already has O rings, should I use Deere parts or the Boling parts?
Thanks,
CB
Frank in Florida
02-04-2007 18:14:12
 Re: 2130 load control seals followup questions in reply to Charles Branch, 02-04-2007 16:16:33
I have replaced the load shaft seals on my 2130 without removing the rockshaft assembly. I just moved the shaft over just far enough to get to the seals.
Then move the other direction to get to the other seal. But if the shaft does not slide over easy I would back off the negative stop.
Frank
