industrial vs ag tractor
Bill Wy.
02-04-2007 12:17:56
I have a couple of questions.I have aways understood that a industrial John Deere tractor is built heaver/stronger than a utility ag tractor of the same size and horse power. Is this true?
I'm thinking about a 401C or a 3020D to put a snow blower on and for road maintenance. Would these tractors be a good choice? Thanks
1020gas
02-05-2007 15:47:49
 Re: industrial vs ag tractor in reply to Bill Wy., 02-04-2007 12:17:56
The 1020 has either a 6.5 GPM @2500 engine RPM or a 13 GPm @ 2500 engine RPM.
The 6.5 was only available on the early 1020 with open center power steering. And I believe that if the early tractors came equipped with more than one hydraulic function installed then they came equipped with 13 GPM pump.
There is a way to tell which is which
jdemaris
02-04-2007 17:56:53
Some of the small utilitie tractors get much better hydraulic systems in the industrial versions. The 1020 ag. versus the 300 industrial is one of example. 1020 gets a tiny little German pump and hte 300 gets the full-size 2.4 cubic inch U.S.pump. In regard to your mention of the 3020 industrial - the industrial versions of 3020s that I've worked on were 500s.
msb
02-04-2007 13:59:06
Typically , the front axle is beefier and heavier since they have to withstand heavy and sometimes abusive loader applications. Front radiator shielding and hood are also much heavier.Tractors are usually equipped with industrial tires for the same reason.
