1946 D electrical
Tom/Idaho
02-03-2007 19:49:55
Several months ago I took everything apart and thought I labeled all the wires. Now it's painted and going back together. The wire from the 'F' terminal on the 12 volt pos ground gen goes where? My notes said it goes to the light switch. The light switch has two terminals. One brings the power from the amp guage and the other takes the power to the lights. Or, does it go on the 'resistor' terminal on the back of the switch? Any assistance will be helpfull.
Tom?idaho
Tom/Idaho
02-04-2007 05:42:40
 Re: 1946 D electrical in reply to Tom/Idaho, 02-03-2007 19:49:55
John T, thank you for your assistance. I will finish hooking it up today. Tom/Idaho
John T
02-03-2007 20:01:11
Tom, is the wire from the gennys Field post Green on Yellow???? Regardless, the wire from F on the genny goes to the resistor light switch terminal best I can tell. The light switch ought to have a BAT input terminal wired to the load side of the ammeter while its light output terminal (hot when lights switched ON) wires, of course, to the lights. On the light switch with all wires removed you can ohm it out to insure its wiring, the BAT input to the Lights output terminal would be an open circuit when switch is off but a closed circuit when switched ON. The resistor terminal to case ground ought to be around 3 ohms when lights are off (low charge) but a closed circuit (high charge) when they are ON. The switch needs a good clean to dash/frame ground so the gennys field post gets either dead grounded (high charge when lights ON) or grounded via the series 3 ohm resistor (low charge when lights OFF)
John T
