1936 JD B
Don Burke
02-03-2007 12:17:42
bought a 1936 B and have a set of round spoke F&H for it. F&H and HC 177 (or 777 ) is cast in center of wheel. was this original for a 1936. I also has F&H adjustable front wheels. Was this from factory?
the flying belgian
02-04-2007 16:54:12
 Re: 1936 JD B in reply to Don Burke, 02-03-2007 12:17:42
I don't believe th adjustable spokes were avail. from factory. we have a 1936 model and up untill 20 years ago we used it to pull a sprayer with. Pa had put a set of pressed steel wheels on it from a newer "B" when spraying so he could turn them inside out for more width so as not to plug up with mud. when he stopped uing it for spraying and restored it he put the orig. spoke fronts on. and they were not adjust.
Don Burke
02-03-2007 14:09:12
thanks for reply. I will get numbers off front wheel and reply .
Don Burke
02-03-2007 14:25:01
 Re: 1936 JD B in reply to Don Burke, 02-03-2007 14:09:12
The casting number on front wheels is W278 D F&H. Do you know where I can get some more clamps for these wheels?
I couldn't find any numbers on rims without unmounting them
Duane Larson
02-03-2007 13:25:12
Don,
Your unsB rear wheels are F&H 177, and your fronts are (likely) 3-way adjustable F&H W273D wheels. The fronts were available aftermarket, but I do not believe they were furnished by the factory as there is no such identifiable wheel listed in the Unstyled B Production Register.
I would appreciate a confirmation on the front wheel casting number.
1936
02-03-2007 12:30:54
Say more about the frt adjustable wheels?
Don Burke
02-03-2007 13:04:20
 Re: 1936 JD B in reply to 1936, 02-03-2007 12:30:54
The front wheels can be set to be close together or be set to be wider apart by using the clamps.
