Forozen? hydraulics on a 2010 industrial
ERICC
02-03-2007 09:23:25
Hi,
I went out to plow the driveway with my 2010 with a 720 loader and the hydraulics for the loader/backhoe don't work. It appears that nothing is circulating thru the system. Could there be ice traped in the lines or in the oil tank- it's about 20 degrees. I bought it this summer and hydraulic oil appeared to have a lot of water in it but I drained, circulated the and re-filled the tank twice to try to get the water out. I'm just not sure what to do- Is it possible that the pump stopped working- it is a cessna gear drive pump.
Thanks for any help!!!!
Eric
msb
02-03-2007 20:29:23
 Re: Forozen? hydraulics on a 2010 industrial in reply to ERICC, 02-03-2007 09:23:25
Did you change the filter? Its located in the reservoir.Think you have to remove about 6 capscrews on the top of the tank to get to it.
Ericc
02-04-2007 04:02:47
 Re: Forozen? hydraulics on a 2010 industrial in reply to msb, 02-03-2007 20:29:23
I found that the filter was full of forzen oil (ice)- looks like I have more flushing to do!
Nylon
02-03-2007 13:18:53
Eric,
My myers snowplow will suck snow/ hydro fluid melt in from a leaking coupler. Ususally it isn't much of a problem. Sometimes though the filter screens will ice and plug and I can't lower the plow. I either have to put a torch on the casting or better yet is to make room in shed and warm up till everything melts and drain off the water at a low drain. Typically isn't much...just enough to get caught in the screen then ice it solid.
