2940
SKYBOW
02-02-2007 20:11:34
I'm bringing my "new" 2940 home from the dealer on Monday. Has about 6000 hours. I'm happy with the price and the dealer. Any suggestions on what I should do to get me and my new partner off to a good start. I intend to change the oil and filter;grease all the fittings. Should I replace the antifreeze and add conditioner? Should I replace the hyd flulid and replace the filters? Is this wasted money? Just wanted some opinions. Thanks
Tyler Horner
02-03-2007 18:50:35
 Re: 2940 in reply to SKYBOW, 02-02-2007 20:11:34
The Deere dealerships have an oilscan, coolscan and hydraulic oil scans that are relatively inexpensive for tractors and combines. If you buy the kits and take samples, they can tell you much more than a ph test strip or looking at the color of the oil. If you had trace amounts of engine oil in the antifreeze, the scan would show this. It is well worth the money. If your tractor has the hi-low transmission, it wouldn't hurt to get the trans.lube oil pressure checked down the road (psi reading). This could prevent costly breakdowns in the future.
G/MAN
02-03-2007 11:21:02
Definitely test and/or replace the coolant. Your JD dealer should have test strips. It can be completely devoid of the necessary additives and still be "nice and green". And simply adding conditioner also isn't a good idea, because if the coolant IS up to par, it's possible to overcondition the coolant which can be as bad as no additive package at all. Same goes with the hydraulic oil and filters - find out if it has been done (and make sure they have some sort of proof that it does - there should have been an internal work order opened for needed maintenance and repairs to a used tractor). Don't assume anything has been done, because if the tractor is in good shape and working properly, a lot of dealerships will just check the freeze protection and call it good. Some because they want to get by cheap, and some because they know that the new owner of a used tractor might prefer to service the machine out himself and use whatever fluids and filters he prefers.
justfixin
02-02-2007 20:30:56
check with dealer what thay did to the tractor first, i would either test the coolent for nitrate or just change it if it isnt nice and green, those engines were notorious for eating sleevs. change hydrolic oil and filter, check out suction screen for brake matieral when you have the hydrolic oil out. might want to set engine valves with that amount of hours on it other than that thay are a great tractor, good luck
Mike M
02-03-2007 05:24:13
 Re: 2940 in reply to justfixin, 02-02-2007 20:30:56
Well said, he should do all of that. Make sure you get them to give you an owners manual too !
