4010 Gas Bareback
mike nelson
02-02-2007 15:01:54
Ran across a JD 4010 Gas Bareback, it has no rocker shaft, just a "pedestal", looks factory.
Does have single hydraulics. Does anyone know how many of these were made and how rare they are?
G/MAN
02-03-2007 07:44:21
 Re: 4010 Gas Bareback in reply to mike nelson, 02-02-2007 15:01:54
They're around - go to wheat-growing areas and you'll find bareback tractors here and there. I worked at a New Holland dealership and our yard tractor was a 4020 LP with no rockshaft. That's probably a little rarer bird yet.
ET
02-03-2007 03:14:12
I run a maintenance shop for a state agency. We have a 4010 gas bare back as you call it. It is used to pull a bush hog mower to maintain a water fowl habitate along the St. Lawrence river. I got it as surplus from the prison system where it also pulled a mower. There is just under 2000 hrs. on it now and its one of the best origonal 4010's I've seen. It still has the foam pad glued to the bottom of the platform.
5020s rock
02-02-2007 21:57:47
hi--i think you should do some investigating
ive seen 4010g stds. and 3020g utilities sell for
14,000 plus..... .good luck
5020s rock
02-02-2007 21:56:59
Dean in iowa
02-02-2007 16:53:47
I have a 1967 Jd 4020 row crop gas, and it too, has no rear rockshaft. I am second owner. The original owner bought it new and ordered it that way from the factory. It has diff. lock and dual hydraulics. I have pictures of it if anyone would like to look. It has completely different sheetmetal around the seat. Is there anyway to find out how many were made like this?
Mike M
02-02-2007 15:27:32
It may even be an industrial ?
dds-inc
02-02-2007 15:18:16
if it is rowcrop, that would be even more unusual
95CS
02-02-2007 15:13:03
No way of telling how many "4010s" were built without a rockshaft. I've seen a few "bareback" "4010" Standards, but never a gas-burner. If the tractor is a Standard, there were less than 100 built, all told.
