4230 Lights
H2
02-02-2007 10:50:57
My 4230's lights are too dim and I'm not sure where to look. The voltage is too low for some reason. I checked the dimmer switch and tried a clip on ground at one of the lights with no success. Any suggestions on why the voltage is too low? Battery is fully charged.
Loren Viterna
02-03-2007 05:08:23
 Re: 4230 Lights in reply to H2, 02-02-2007 10:50:57
The lights on my 4230 did the same thing. Turned out to be the big relay under the LH cowl panel by the steering wheel. The relay would click and externally give the impression it was working. Had low voltage and dim lights. Another relay solved the problem.
H2
02-05-2007 04:53:15
 Re: 4230 Lights in reply to Loren Viterna, 02-03-2007 05:08:23
Thanks Loren. This sounds like what the problem is. I'll change it out and see.
matthies
02-02-2007 18:34:49
Have you added more lights, checked the connector under the right front of the cab(white rectanglar shape) that could be dirty/corroded, or the back of the light switch gotten hot or brighter/dimmer with fan/accessories running?
H2
02-03-2007 04:44:08
 Re: 4230 Lights in reply to matthies, 02-02-2007 18:34:49
No, the lights have been this way since I bought the tractor 2 years ago. It has the stock lighting package on it. My guess is a bad groung somewhere, bad main connector since all the ligts are dim, or bad switch.
There should be a circuit breaker somewhere as there is on my combines and other older Deere. Could be that it has a poor connection internally.
daryl kennedy
02-02-2007 16:50:49
have they always been like this or something new
did you change something latley
could be the lights are in series and not parrelle
this would cause the lights to be only have voltage
