3020 altenater wiring
JS FARMING
02-02-2007 07:51:17
had 24 volt system got everything except the altenater and switch wiring
matthies
02-02-2007 18:29:49
 Re: 3020 altenater wiring in reply to JS FARMING , 02-02-2007 07:51:17
They also use a solenoid(what ford used to have on the fender well for their starters). They say to hook both original ignition wires to one side of the solenoid and also a wire from the top post of the solenoid of the starter and the other side of the ford solenoid to the "S" terminal of the starter solenoid. Then hook original tractor start wire to the top of the ford solenoid to energize it, making the 12 v starter work. If anything of this is confusing I'll try and make it easier. Also you might need a Gates 9580 belt if the original is the wrong length. Whats your serial number of your tractor, above or below 91000.chris
Glen in TX
02-02-2007 07:59:43
http://jdparts.deere.com (see parts catalog)
