JD B spark plugs
mopar92
02-02-2007 07:08:16
I just rebuilt my JD B and the head has the inserts so I can use platinum spark plug will they work with a mag? Or what is a choice for a spark plug. Are they worth the money? Or is their a better choice?
Glen in TX
02-03-2007 10:23:57
 Re: JD B spark plugs in reply to mopar92, 02-02-2007 07:08:16
I just haven't played with the 14mm plugs in bushing adapters enough to know which ones would work well in your JD. Some of the tractor puller guys may can tell you but keep in mind they may be running a different fuel and lot higher compression or electronic ignition also. It's just important to run the hottest plug you can and keep the engine temperature up high so gasoline vaporizes enough and avoid lots of idling to keep plugs from fouling with todays gasoline. Good idea to have and even use shutters or radiator curtain on them today if you aren't taking it out to the field to work. Besides the Autolite 3116 plug others in 18mm size that can work for you are Denso L14-U, AC C88 or C88L, and Champion D21 or D23. Keep in mind the D23 has longer insulator that will interfere with spark plug covers. Many will cross you over to Autolite 388 or 386 but their cross charts are wrong as those plugs are resistor type and shouldn't be used with magneto ignition. If you want to use resistor plugs with battery distributor ignition they could be fine. You are just going to get more fire to the hole in these old JDs with metallic core wires and non resistor plugs using the standard ignition systems they came with.
mopar92
02-03-2007 06:53:56
john t, glen in tx, thanks for the info this tractor is really my brother , who lives in tx. im going to get a answer or have my brother post a reply Mike
John T
02-02-2007 08:06:32
Mopar, I dont see platinum tip or otherwise as an issue, so long as the plugs heat range is suitable and theres no clearance problems it ought to work. I agree with Glen, especially on Mag ignitions where the energy is low and limited you want to discharge all the avaiable stored energy across the plug gap versus wasting it as heat in any wire or plug resistance. Does it still take 18 mm plugs such as Autolite 3116??
John T
Glen in TX
02-02-2007 07:31:11
It's your tractor so use what you want but I recommend non resistor plugs and metallic core wire with a magneto ignition. That will get you more fire to the hole with a mag and longer life out of the mag.
Glen in TX
02-02-2007 07:32:57
 Re: JD B spark plugs in reply to Glen in TX, 02-02-2007 07:31:11
Oh and that's not just my opinion but what many magneto and coil manufacturers also recommended over the years for warranty issues.
