5020 weight
Angle Iron
02-02-2007 03:21:41
I may need to haul a 5020 in the near future and need to know the weight. It has duals with cal in the inside set, no other weights on the rear. The front weights have been removed. We have a mid 80s ford 600 single axle dump and a hudson pintal hook 12 ton trailer. I know the weight of these need to know about the 5020.
Thanks Angle Iron
Glen in TX
02-02-2007 07:37:14
 Re: 5020 weight in reply to Angle Iron, 02-02-2007 03:21:41
Was around 13,000 + or - shipping weight so yours will be more 15,000 - 22,000.
BLinWMi
02-02-2007 11:26:58
 Re: 5020 weight in reply to Glen in TX, 02-02-2007 07:37:14
well mine had duals and all 4 tires were loaded, no other weights on the tractor, also it has a cab. Mine weighed in at 20 pounds less that 10 tons, hope this helps
jdeere70
02-02-2007 05:07:16
Your trailer should haul it ok. I`d guess the weight at 17,000 to 20,000 lb.
