JD 1010 radiator or parts tractor wanted
Perry Missel
02-01-2007 12:27:49
Looking for a good used radiator for a JD 1010RS or a parts tractor in the Mid Atlantic states.
James Dillard
02-06-2007 02:01:39
 Re: JD 1010 radiator or parts tractor wanted in reply to Perry Missel, 02-01-2007 12:27:49
Still interested in a 1010 parts tractor? Email me if you are I am near Augusta, Georgia.
rocketman
02-01-2007 14:45:43
 Re: JD 1010 radiator or parts tractor wanted in reply to Glen in TX, 02-01-2007 12:46:37
Thanks, Glen - No, Wengers doesn"t have it, and yes, it can be repaired at a local shop ... but the one shop it"s been to, the guy thought it was gold .... if you know what I mean. I"m just trying to help out a neighbor who doesn"t use a computer.
Thanks,
Perry
Glen in TX
02-02-2007 07:48:06
 Re: JD 1010 radiator or parts tractor wanted in reply to rocketman, 02-01-2007 14:45:43
To add to Mike's comment on fixing one yourself if you have a old rubber inner tube laying around you can cut it and fasten to inlet and outlet of radiator putting some light air pressure on it and lower into a stock tank to check for leaks and try fixing yourself. I've fixed several old truck heater cores that way myself.
Mike M
02-02-2007 07:32:07
I priced used ones for my LA and thought they were gold too. I just couldn't see paying very much for one used with no guarentees it was any better than mine. So I just grabbed the acid core solder and torch and went after it,rigged up a way to fill it with antifreeze to test it. A few spots needed redues and I was in business.
