1952 JD B front fan bearing
Paul_IN
02-01-2007 04:03:49
I"m restoring a B and wondered if it is sufficient to pack the front fan bearing with wheel bearing grease? There is a pipe plug provided in the housing but it seems that the housing would have to be filled up a good ways with grease to reach the bearing. Seems like a good way to make a big mess as I doubt that felt on the front of the housing will seal it up good enough. What do you think?
CalJim
02-01-2007 21:43:39
 Re: 1952 JD B front fan bearing in reply to Paul_IN, 02-01-2007 04:03:49
Packed mine full when rebuilding fan shaft.
When I started motor for first time I had a
small amount come out through the felt. It
seems o.k. now, probably had too much in
there to start with. I removed pipe plug and
installed a 90 degree grease zerk so I can
fill when needed. CalJim
Mike M
02-01-2007 04:45:48
I guess it all depends on how much running time it will see ? If packed it will only last so long ? I pack them and then after it's together pump a bunch of grease in there and carefully watch the front pulley for movement and spin the shaft too. If the pulley moves or the shaft gets stiffer STOP. I have not had a problem with it flying out with new felts installed. I can't say as that I have seen a bearing failure from too much grease ?
Pappy
02-01-2007 21:46:17
 Re: 1952 JD B front fan bearing in reply to Mike M, 02-01-2007 04:45:48
I have made grease fittings for mine using a 1/4 inch pipe plug and a grease zerk. I drill a relief hole alongside the zerk so any excess pressure will be relieved. Works for me.
Kurt_JDB
02-01-2007 04:37:25
Paul,
The pipe plug is a place where you can put grease in to lubricate the bearing, however, If your fan shaft has not been apart and serviced in many years, it may be a better idea to remove the fanshaft and governor so you can take it apart and clean it up before you grease it and put it back together.
JD recommended in the operators manual to have the fanshaft bearing dissassembled, cleaned and repacked with grease every year. This was probably excessive.
If you do decide to take it apart, you will need a hydraulic press. You might consider renewing the friction disks in the fan clutch at the same time, and carefully inspecting the governor bearings and weights. Also be aware that the heel and backlash of the governor/fanshaft gears are set by the thickness of various gaskets.
I rebuilt the governor and fanshaft on my '51 B about a year ago. The most difficult task turned out to be removing the keeper at the end of the shaft. The pot metal fan clutch disks were stuck and would not slide back on the shaft to releive the keeper. I finally cut them off after buying a new set from Deere.
Kurt
Paul_IN
02-01-2007 08:16:19
 Re: 1952 JD B front fan bearing in reply to Kurt_JDB, 02-01-2007 04:37:25
I do have it all apart now. Like you, my aluminum drive disks were stuck bad - I melted mine off with a torch. Anyway, I've got everything cleaned up a new felt for the front. I'll pack the bearing and probably go ahead with what Mike said to get some grease in there but be careful.
Mike M
02-01-2007 08:25:46
 Re: 1952 JD B front fan bearing in reply to Paul_IN, 02-01-2007 08:16:19
While rereading all this I thought of another good reason to get it kinda filled up with grease. I would hate to see that void in there collect moisture from condensation and rust stuff up. High moisture is a big problem here in Ohio anyhow.
