4630 enigne noise
Carl B.
01-31-2007 19:10:39
Got a 4630 that has kind of a tick/slight knock. Only noticable around 1000 rpm. Sounds like it's coming from the top of the engine. This engine has about 1500 hrs. on a full overhaul. No other noticable engine problems. I'm sure it's not the hyd. pump coupler, as I have replaced the bushings and clamps. Good friend has a 4640 with the exact same noise but louder, and I have heard this same noise in other bigger Deeres. What's going on?
G/MAN
02-02-2007 07:42:55
 Re: 4630 enigne noise in reply to Carl B., 01-31-2007 19:10:39
Could be a valve adjuster jam nut backing off - that can happen pretty easy if the technician didn't tighten them well. The aluminum hold-downs for the rocker shaft also break from time to time, or on the bolts for those may be backing out. Cracking the injection lines loose one at a time should help pinpoint the sound and isolate the cylinder.
msb
02-01-2007 08:46:17
Could just be a noisy Injector nozzle. Use a stethescope(sp?) or an large screwdriver held in your fist,and against your ear to determine where the noise is coming from.
justfixin
01-31-2007 19:20:31
try setting the valves
4010 Pride
02-01-2007 08:15:05
 Re: 4630 enigne noise in reply to justfixin, 01-31-2007 19:20:31
I will agree. My 4010 did that after a major overhaul a few years ago. I had the inj. pump rebuilt and properly timed everything upon reinstallation. But...at full throttle it produced a sound kinda like a spark knock in a gasoline engine. I had the exhaust valves adjusted and it was fine after. Good luck.
