2940 hydraulics
skybow
01-31-2007 08:57:02
It's very cold today. 0-5 degrees. MY 3-pt on my 2940 seems slow today. After I warmed up the tractor THe three point went down very very slowly. It comes up fine. Is this because of the temp?
sting0270
03-20-2007 22:30:32
 Re: 2940 hydraulics in reply to skybow, 01-31-2007 08:57:02
hey im working on 2940 john deere tractorbe for i put hi lo cluches in it it all work now it dont work we ant get no oil in the pump in front one how do the oil flow throw it do u have a any way show me how the oil flow throw the pump to get oil to the front of the tractor
Mike M
01-31-2007 10:56:02
At that temp. it's a wonder anything works at all ??? I know I don't. If your going to do much at those temps. you may want to check into putting in low viscosity Hy-Gard ?
WTW
01-31-2007 10:41:08
It is just that the oil in rockshaft cylinder is cold. You can open the lowering rate control valve located between you feet but doing this will allow the rocksfaft to drop fast when the oil is warmer or when you have a heavier load on hitch arms. The valve has a flat iron arm attached to it and backing it out will open lower valve and increase rate of drop speed. DW
skybow
01-31-2007 20:35:37
 Re: 2940 hydraulics in reply to WTW, 01-31-2007 10:41:08
Thanks guys!!
