Crankshaft Play in a '40 Model B
Paul Durbin
01-30-2007 18:45:06
Following a complete engine restoration, I hook up the clutch linkage and adjust. I noticed when engaging and locking the clutch arm, the crankshaft moves in the direction of the clutch side. I don"t see any adjustment and am wondering if this "play" is normal and designd. The crankshaft moves about 1/4 inch.
Is this normal?
04-23-2007 07:02:13
 Re: Crankshaft Play in a '40 Model B in reply to Paul Durbin, 01-30-2007 18:45:06
Would this cause it to knock? I am re-ringing my tractor right now and found the same issue. It was knocking and thus far I have not found a reason for the knock.
Thanks!
Kevin
1947 JDB
Alex-41JDb
01-30-2007 19:01:54
Yes this is common. You need to loosen up the flywheel and put it on farther. Someone will give you the exact spec which is next to nothing. Basically put it on with very very little play.
Paul Durbin
01-31-2007 03:48:21
 Re: Crankshaft Play in a '40 Model B in reply to Alex-41JDb, 01-30-2007 19:01:54
Thanks for your help!
Duane Larson
01-30-2007 18:59:39
Paul,
Your flywheel is not slid on the crankshaft far enough. Put a block between the crank end and the wheel on the pulley side, loosen the flywheel, and shove it in, snug it down, and check lateral movement - do this until you get 5-8 thousands lateral crankshaft movement. Then tighten the flywheel back tight and you should be good to go.
Paul Durbin
01-31-2007 03:47:34
 Re: Crankshaft Play in a '40 Model B in reply to Duane Larson, 01-30-2007 18:59:39
