A trans. back together
Hig5060
01-30-2007 18:39:19
Well guys I got my trans. back together without any trouble. If you remember I couldn't find any bad bearings just some gears a little battered from rough shifting. So I didn't really fix anything but just know it shouldn't fly apart on me. Should I try to find some real heavy oil of some kind to put in it? I remember seeing somebody recomend it. If so what kind should I get? I hope it helps some cause I hate to hear all that noise. Thanks guys!
Kurt_JDB
01-31-2007 06:02:36
 Re: A trans. back together in reply to Hig5060, 01-30-2007 18:39:19
140 wt in GL1 ought to do the job, if it does not get too cold where you are.
Kurt
Mike M
01-31-2007 04:58:53
Do you have fenders on it ? if so take them off as they are amplifiers.
Earl-IL
01-30-2007 21:05:07
I use 85-140 helps with the noise. Earl
Sam from WA
01-30-2007 20:18:12
put 80-90 weight in it. its multigrade, so it serves for both 80 and 90 weights. we run 80-90 weight in everything around here, never had a problem. Case and Case IH brand oil is what we use.
