JD 420U oil filter sealing plate
Bill420U
01-30-2007 14:20:41
I see on eBay a JD Part # M88T reproduction oil filter sealing plate starting at $11.95. On my 420U, it is missing but does it really affect operations, oil pressure readings? For something that looks like an oversize washer, I think it is a little pricey. Does anyone have its dimensions (diameter, hole size, thickness) so I could find a washer like it? Thanks
jCarroll
01-31-2007 20:45:58
 Re: JD 420U oil filter sealing plate in reply to Bill420U, 01-30-2007 14:20:41
Dimensions are on www.jd40(dot)com
OD is 3"
thickness is 1/10"
ID is just big enough to fit over the oil filter casting - I think it's a large 1".
Mike M
01-31-2007 12:42:35
Nothing fancy about them. There is a shoulder on the bottom of the filter housing it sets on so just measure that and for an OD anything up to the OD of the filter should be ok. I was thinking I made some from the filter plate/washer from like an A or B that you can still get from Deere not positive though ? I may of just found something laying around ?
billde
01-30-2007 14:52:52
You do need that plate, it supports the filter so that the filter retains it's shape. Without it the filter is not very effective.
Wayne in Tn.
01-30-2007 15:29:49
 Re: JD 420U oil filter sealing plate in reply to billde, 01-30-2007 14:52:52
Most of the oil filters you get nowadays have a metal base. I have owned several Dubuques, and that washer was missing. They still had normal oil pressure and never had one to distort the filter. That nut on top of the cannister just tightens it against the base and seal. There is a spring in the cannister that puts slight pressure on the filter itself.
Rockbasss
01-31-2007 08:55:44
 Re: JD 420U oil filter sealing plate in reply to Wayne in Tn., 01-30-2007 15:29:49
third party image
I have a '58 420U and the washer was missing also. The photo is the filter that I use. The one on the left is the new one that replaced the one on the right. The style change a bit but the dimension are the same.
Bill420U
01-31-2007 14:30:49
 Re: JD 420U oil filter sealing plate in reply to Rockbasss, 01-31-2007 08:55:44
Mine is a regular JD filter AH1082R and it has paper ends. Both the ones you have shown look much stronger. I"ll consider them next time.
Meanwhile, no one has submitted the plate"s dimensions but if these WIX filters have metal ends, then my concerns are addressed.
Thanks all for their useful explanations.
