3010//2940
SKYBOW
01-29-2007 13:16:18
Went to do a compression test on my 3010 as it wouldn"t start and had been losing power as of late. Well I"ve got oil coming out of th #1 sparkplug hole. I"m thinking of trading it in on a bit more HP. Looking at a 2940 but no one wants to give much for my 3010. Suggestions??
Tyler Horner
01-29-2007 19:41:52
 Re: 3010//2940 in reply to SKYBOW, 01-29-2007 13:16:18
Be careful with the 2940's/2950's--they had their fair share of hydraulic related problems and are a little expensive to fix thanks to their German origin. I work for a 14 dealer group in the mid-atlantic, and I have seen a few come thru the shop. Engine is great, hydraulics are something else. Do yourself a favor and try a 4040, 4240 or a 4050--around the same HP and less headaches.
Tyler
AtlanticTractor.net
buickanddeere
01-30-2007 14:20:36
 Re: 3010//2940 in reply to Tyler Horner, 01-29-2007 19:41:52
What goes wrong with the hydraulics?
Tyler Horner
02-03-2007 16:15:12
 Re: 3010//2940 in reply to buickanddeere, 01-30-2007 14:20:36
If your 2940 has the hi-low transmission, the internal linkage would wear over time causing a drop in psi of the lube oil pressure. As a result, the hydraulic oil would not properly lube the other componets, such as the transmission clutch packs for example. In the end, the owner would have to pay to split the tractor and replace the packs and whatever else. My advise to you is to check the hydraulic lube oil pressure at your local dealer. If it is within specs, you know you have a good, tight tractor.
Tyler Horner
02-01-2007 18:55:30
I will post some details tomorrow--I've been away for the last couple of days. I have one neighbor down the road get over $5000.00 worth of hydraulic work done to his, and it still isn't right. It was fixed at another Deere dealer, but we have had a few come in our shop as well.
Mike M
01-29-2007 16:03:48
A 2940 is a nice machine ! A 3010 gas won't bring much running good let alone needing engine work. Where you at and what do you want for it ?
skybow
01-29-2007 17:53:06
 Re: 3010//2940 in reply to Mike M, 01-29-2007 16:03:48
I"m near Des Moines, IA. I need to get about $3000 out of it to break even.
Mike M
01-29-2007 18:49:30
 Re: 3010//2940 in reply to skybow, 01-29-2007 17:53:06
I don't know ??? IF it has a wide front and looks decent and can still run you might try ebay. If it is a narrow front ? you may loose money. But at this point any money you spend on it is going to be more losses. You may need to cut and run ! to quote senator Teddy.
j cook/iowa
01-30-2007 08:41:51
 Re: 3010//2940 in reply to Mike M, 01-29-2007 18:49:30
Senator Teddy was more famous for "Crash" and run, wasn't he?
Mike M
01-30-2007 09:39:06
 Re: 3010//2940 in reply to j cook/iowa, 01-30-2007 08:41:51
Ya that too !!!! LOL
