3020 throttle
JR in TX
01-28-2007 19:08:42
I have just purchased a late model 3020 that worked fine when I brought it home. I used it for a day the parked it all week. When I started it up the hand throttle doesn't work, all it does is when I go all the way down the engine runs slightly above idle. The foot throttle works fine. I watched the linkage and the hand throttle just doesn't move it as far as the foot throttle, but I doesn't look like that much difference. Also it is a diesel with a syncro and when I push in the clutch I loose all hydraulics even steering in less than 10 seconds. I know about the charge pump in the transmission but shouldn't I have steering longer than that. I have a rattle from the engine area that comes and goes, any idea's, common problems? The brakes growl and lock up quickly, where are the pads located? Yes I have the manuals ordered but I was just looking for friendly advice before they arrive.
Lincoln
01-29-2007 19:00:57
 Re: 3020 throttle in reply to JR in TX, 01-28-2007 19:08:42
The rattle from the engine area my be the coupler between the front of the engine and the hydraulic pump.
Gerald J.
01-29-2007 11:32:45
The throttle linkage on my gas 4020 fell apart one spring. I put it back together and made replacement parts, but it hasn't fallen apart again.
Yes, when you have the charge pump check valve failure you loose power steering rapidly after you push in the clutch. There's only one hydraulic pump for all the hydraulics and when it doesn't have oil you don't have pressure.
If its a pre side console 3020, I have the fix for that loss on my web page http://www.geraldj.networkiowa.com/4020si.htm Its not a difficult or expensive fix.
If its a later 3020 then that has no effect and there are other places to look, including looking for pressure line leaks in valves and fittings though there is also a check valve in a T near the front oil reservoir.
Gerald J.
msb
01-29-2007 09:56:58
There are 2 ball joints in the linkage that ofter come apart.They are located under the dash . The only real cure is to replace the one that has come apart.I have on occasion put them back together and used a hammer and chisel to retighten them in the socket.
JR in TX
01-29-2007 06:12:01
Thanks for the suggestions and that parts link that is great! That is how it seems for me too when I buy somthing. Do you have to split the tractor to change the brake pads? How do you access them? Thanks again!
Bob
01-29-2007 06:38:38
 Re: 3020 throttle in reply to JR in TX, 01-29-2007 06:12:01
The brakes are "wet"... they are bathed by the rear end/hydraulic oil.
If the pads are bad, you will have either brake pad material or metal shavings in the hydraulic sump screen and hydraulic oil filter.
To replace them, the final drive on either side has to be split away from the tractor. The brakes are in there, next to the planetary fial drives.
Mike M
01-29-2007 05:35:11
Isn't that always the way it works out ? They fall apart as soon as I get in my driveway !
I bought an old model 50 JD and when I looked at it was sitting outside battery cables and wiring all frayed and bare spots bad cable ends what a mess ! The guy that owned it took a vise grip clamped what was left of a cable to the battery post and it poped right off ! Well a couple of days later went to get it same thing poped right off ! loaded it up only went about 15-20 miles and once at my house I couldn't get it to start for nothing ! I had to drag it off with another tractor. It has since been gone clear through and last time I tried it poped right off like it should. Had something similar on my 720D I even drove it home at least an hour or more drive ! seemed fine ? even mowed the pasture. Then I proceeded to change the oils. What a disaster ! parts and pieces of gear teeth, weight pins and everything else came out !!!! I was ticked off ! tore it clear apart ALL THE WAY. $5,000 in parts ( 1985 prices )and a year later I finally had a good tractor.
Glen in TX
01-28-2007 21:39:54
JR, You should be able to see the parts catalog online for it too. On the throttle pull the dash cover or lower dash panel too taking a look at linkage. It may just need lubricated some where it meets up with the foot pedal or something worn or broke. Check the friction pad adjustment on steering tube and also to see if lug on tube for throttle has broke off or cracked. You can usually braze the tube back if so not having to replace it but if all oily under there better pull it out first. Sometimes the little rods are just worn out too. If hydraulic oil and filters and charge pump intake screen hasn't been changed in a long while may want to try that first and see what oil and filters look like and then do some pressure tests later if still problems. Brakes are inside trans behind axle housings.
