JD 450C Main Clutch does not work
mjb8279
01-28-2007 19:03:39
I recently purchased a JD 450C but the foot clutch does not work (the crawler does not stop with the clutch pushed in - the clutch does not disengage). I looked the technical manual to see how to adjust the clutch but the manual does not describe any external adjustments. Does anyone have any ideas?
Thx!
Roy Suomi
01-29-2007 16:11:53
 Re: JD 450C Main Clutch does not work in reply to mjb8279, 01-28-2007 19:03:39
One thing you must understand is , the top 4 inches of clutch pedal shuts off oil..It does not disconnect the engine clutch..When you push down the pedal it first dumps oil to the clutchpacks then you feel resistance for the engine clutch . Once you push the pedal further into the engine clutch it should disconnect everything.. You should probably scout for an "old fossil" to look at your problem..Most of the "kids" don't have the feel for the old HLR transmission..
jdemaris
01-29-2007 06:40:09
You must be looking in the wrong place. It is well described and it's a critical adjustment - because the main engine clutch linkage has to be in sync. with the hyraulic pressure valve for the HL-R transmission.
