420 S
Bob Evans
01-28-2007 12:45:47
I posted a while back on a 420 S that starts good has good oil press and runs good with no smoke except when throttled down,Then it smokes.Several responces said a seal or type of bushing was worn and letting oil get into the combustion chamber.Question = what type of seal or etc.should I ask for at the parts dealer.
Henry M
01-29-2007 05:32:59
 Re: 420 S in reply to Bob Evans, 01-28-2007 12:45:47
Bob
What color and consistency is the smoke.
By the way, my parts book shows two seals/oil deflectors being used. When I got my head back from the shop they had installed oil seal bonnets on all the stems.
Bob Evans
01-29-2007 13:06:39
 Re: 420 S in reply to Henry M, 01-29-2007 05:32:59
Henry the smoke is blue.No black smoke when at an idle or full throttle.Surely the parts man will know what I need.I just wanted an idea of what to expect.Thanks to all who responded.
CPeter
01-28-2007 15:34:56
There are no real seals on the valve stems and under high vacuum conditions they will draw a little oil past the stems though the guides and that makes a little blue smoke. I have heard of people using Chevy type seals to stop this, but have actually seen it done.
CPeter
Ray
01-28-2007 13:41:05
Are you sure it's not a carb problem? They were known to run rich at idle.I've seen several that had a black smoke exaust at idle.
