1942 A
Frank van den d
01-28-2007 12:28:01
my rear rims are approx 11 in.wide x 38in.dia.what is the max.tire size that i can run?thanx.
P Browning
01-28-2007 12:55:05
 Re: 1942 A in reply to Frank van den dorpel, 01-28-2007 12:28:01
Frank -- If you measured overall rim width (from outside to outside) and found 11 inches, you have a 10-inch wide rim. The tire size would be 11.2 x 38.
Now, if you measured 11 inches inside the bead trough, your tire size is 12.4 x 38. Measuring inside the bead trough is the correct place to make this observation.
These seemingly odd tires sizes describe what is still the same tire as in days of old, but measured now at the widest point of the tire. In earlier times, the measure was the actual width of the tread.
