4010 Longevity
rustin
01-28-2007 11:06:46
Just had a "broad" question on the engine longevity before you have to do an overhaul. I know it all depends on the care given to the tractor & how hard it was worked, but wanted to get a general idea. I found a diesel with 4200 "original" hours. Assuming the hours are correct, how long can one expect before an overhaul is needed & when have others had to overhaul their 4010's?
G/MAN
01-29-2007 07:42:31
 Re: 4010 Longevity in reply to rustin, 01-28-2007 11:06:46
Keep in mind that those are abosolutely not the actual hours. Mechanical tachs only put the true engine hours on when the engine is running at rated speed, which is 2200 rpm or so. Tooling around at 1000 rpm will only put less than a half-hour on the clock for every hour the engine is running. That said, you hit the nail on the head talking about service and how the engine is maintained. Cold starts are hard on engines, and engines that are started and shut off frequently usually don't get warmed up enough to keep the condensation cooked out of the engine oil, etc. Generally speaking, a tractor that is started once or twice per day and that is properly operated and no overloaded or abused but is kept under a good load will outlast a tractor started 20 times a day and puttered around with. Diesel engines are made to work, not loaf or sit idle for long periods.
Mike M
01-29-2007 12:00:16
 Re: 4010 Longevity in reply to G/MAN, 01-29-2007 07:42:31
I totally agree on those diesels being made to work and starting and stopping not good on them.
That's EXACTLY why I went looking for a GAS model 4020. Had this one for maybe 14 years now ? and have only put 500 or 600 hrs on it. I do alot of starting, stopping and fooling around. Some jobs it's too big for and I had a few it was a little small for. But all in all they are one great all around machine ! MFWD would really be nice, but bought a set of tire chains and it really helped. Best part is I'm betting after all these years I can still get my money back out of it when/if I sell.
big hunter
01-29-2007 06:18:18
a friend of mine bought a 3020 brand new, I forget what happened but shorty after the engine needed a rebuild (it was still under warranty) the John Deere mechanic (my cousin) rebuild the engine on my friends farm (didn't take the tractor back to the dealership) the tractor now has 19,000 some hours on it and still runs good. go figure
Mike M
01-28-2007 11:30:36
An old low houred machine may need sleeves replaced due to corrosion. I have heard of alot of those going to 10,000 + - hrs. without being opened up.
Bob
01-28-2007 11:30:31
If those are "true" hours, and it's been well cared for, wear-wise, it's just getting broken in!
HOWEVER, with the YEARS involved, the liners could be pitted, or the sleeve-to-block "O" rings deteriorated to the point a water leak could be imminent.
Rolling in new bearing inserts and replacing the rod bolts wouldn't be the dumbest thing, either.
