JD wrenchs
lindsey
12-29-1999 15:32:34
I've got what looks to be a dog-bone style wrench that has JD-5C stamped on it. It is about 4 inches long and is flat with a square hole near one end. I have two others that are each successivly larger each with the stamp and one has JD-52 & JD-53. They appear to be part of a set that can be stacked (cause all are flat with that square hole and of same thickness 3/16") Can anyone confirm this and tell me what they were used for/on and what is missing if they are indeed a set. I have a picture scanned in of the small one but do not know how to get it in here.
Leon
12-29-1999 20:57:47
 Re: JD wrenchs in reply to lindsey, 12-29-1999 15:32:34
The small one that you say has JD 5C on it is probably a JD51. It is the smallest of 4-- JD 51,52,53,and 54. They replaced similar shaped wrenches that just had "DEERE" stamped on them. I had a tool collector tell me that JD went to the 50 series in 1923. I don't know when production of them stopped. Apparently though, they were standard issue on lots of different implements.
