8450
Brenty33
01-27-2007 21:57:03
Does any one have any good or bad information on a 8450 jhon deere 4wd
tractorfixer
01-29-2007 10:07:06
 Re: 8450 in reply to Brenty33, 01-27-2007 21:57:03
From my experience, I'd take the 8650 and the 619 as long as left stock. The stock 619 will outlast a stock 466 in a 4wd. The 466 can't take the torque and sooner or later will blow a head gasket. If they are turned up, I'd leave either model set.
G/MAN
01-29-2007 13:44:46
 Re: 8450 in reply to tractorfixer, 01-29-2007 10:07:06
The new gaskets, the new head bolts and the proper torque sequence make all the difference in keeping a head gasket in a 466, along with making sure the head is flat and the liner protrusion is correct. I'd agree that a 466 in an 8450 can have its hands full at times moving that much tractor - you learn to start in a low gear and shift up pretty quickly. They're a little doggy until you start getting some boost built. But I don't think they're any more prone to blowing head gaskets in an 8450 than they are in a 4850. If you turn up the smoke in either, take them out and pull the living daylights out of them lugging them way down all the time, you're asking for a blown head gasket.
G/MAN
01-29-2007 07:37:15
8450s are probably the best of the 30/40/50-series Deere 4wds. Engine repower? I sure don't know why you'd want one - 8450s came with Deere 6466 engines in them, not the more troublesome 6619 found in the 8650. I've spent a good deal of time in my grandpa's late 8450, and it has always been a good, solid tractor. I also put a RemanSelect engine in another 8450 once - no catastrophic failure of the engine, it was just pretty tired with 8000+ hours on the clock. The Perma-Clutch in that tractor still looked new. PTO and 3-point hitch make them much handier. Grandpa's 8450 is about the handiest thing I've ever seen for running a grain cart - plenty of stopping power, plenty of traction and pretty easy on fuel. I believe they were rated around 185 PTO horsepower. His made about 205 the one time I had it on a dyno.
billde
01-28-2007 06:32:56
If it's a repower fine, if it still has the Deere engine make sure you see a service record. Other than the engine just check for normal 4wd wear.
G/MAN
01-29-2007 07:38:21
 Re: 8450 in reply to billde, 01-28-2007 06:32:56
Why a repower? 8450s have 466s in them, which I'd take over any Cummins engine I've ever been around in a heartbeat.
