Do I have a multifuel B?
Kurt_JDB
01-27-2007 20:48:56
I got my serial number research results today for my "51 B tractor from the two cylinder club. Much to my suprise, the tractor was listed as having a distillate engine, which I take to mean a multifuel or allfuel engine
I have not seen any sign that it is a multifuel, no three way valve, no small fuel tank, no hole in the dash for the three way valve control, no extra hole in the hood. Did not have the original carb on it when I bought it.
I guess this all could have been changed around, but are there any other things I can look for to indicate it may have been a multifuel? Tractor did have a mag rather than an XB distributor.
Interestingly enough, the tractor was listed as being originally delivered to Raleigh, NC, which is where I live, although I bought it a few hundred miles from here.
Kurt
Bob Collins
01-29-2007 07:21:24
 Re: Do I have a multifuel B? in reply to Kurt_JDB, 01-27-2007 20:48:56
After reading all the comments , and each one makes sense, no one mentioned that even though great care was made to keep accurate records, John Deere factory folks might have made a mistake recording the engine type back when it was built. I tend to think these guys had a dream job being around history in the making, but to them it was a job and after a "short" night their full attention may not have been on the job.
Mike Aylward
01-28-2007 20:10:43
Kurt, another thing to check is to look under the fuel tank and see if there is a heat shield there. Unless the tractor has been converted (which it sounds like may be a possibility) an original all-fuel tractor would not have had the heat shield. Mike
Kurt_JDB
01-28-2007 20:21:11
 Re: Do I have a multifuel B? in reply to Mike Aylward, 01-28-2007 20:10:43
Thanks for the tip, Mike. I had the fuel tank/hood off last year to put on a new muffler. It does have the heat shield.
Kurt
RalphinWI
01-28-2007 10:15:38
The quickest (cheapest) way to check the engine is to do a cranking compression check. With an All-fuel engine I think it is 70 - 80 psig. If a gas, then it should approach 110 psig depending on the condition of the rings and valves, although I have an A with "taller" pistons with a cranking pressure of 130 psig.
kurt_JDB
01-28-2007 10:47:03
 Re: Do I have a multifuel B? in reply to RalphinWI, 01-28-2007 10:15:38
Thanks,
I have checked the compression, and it is right around 100 on each cylinder.
Kurt
CLW
01-28-2007 08:07:48
Kurt, it could be that 2-Cyl. put in the wrong serial number and not you. I can't see changing hood and all to make it a gas tractor either.
Kurt_JDB
01-28-2007 10:49:32
 Re: Do I have a multifuel B? in reply to CLW, 01-28-2007 08:07:48
I suppose I could give Two Cylinder a hollar and see if they will check it again for me. How do they check these numbers, anyway?
Thanks,
Kurt
CLW
01-28-2007 11:22:45
 Re: Do I have a multifuel B? in reply to Kurt_JDB, 01-28-2007 10:49:32
I think they have the build records from Deere. They put a lot of work, time and money into it but it is possible they misread your number. If you can catch J.R. Hobbs eye he could double check for you, or a call to them may work best.
dds-inc
01-27-2007 21:06:01
you sure you didn't get the serial # mixed up? usually you can just run the tractor on gas with out changing over the hood and gas tank and stuff. That's really odd. If indeed it was originally an all-fuel, it may still have the all-fuel pistons in it. I think that maybe the tractor was put together from a basket case of tractors once upon a time, using various parts from other b's. Not unheard of.
Kurt_JDB
01-28-2007 06:04:27
 Re: Do I have a multifuel B? in reply to dds-inc, 01-27-2007 21:06:01
I did check and recheck the serial numbers. Your thought about the tractor being made up from different tractors could also be the case.
It has also occured to me that the tractor could have originally been owned by the NC State Highway Commission, as the DOT was called in the 50's. I have found a lot of yellow paint under the Green, and the SHC or DOT is headquarted here in Raleigh. The maincase from an all fuel could certainly have been swapped into a gas tractor.
I have also seen in the JD service bulletins that JD sold kits in the 50's to convert an all fuel to gas. These kits contained a new manifold and pistons. I guess a dealer could have gone all the way and put on a new hood and endcap so as to make up a gas tractor if he couldn't sell the allfuel.
Kurt
B-maniac
01-28-2007 11:15:41
 Re: Do I have a multifuel B? in reply to Kurt_JDB, 01-28-2007 06:04:27
The yellow you are seeing is more than likely the "buff" primer they used back then. It was mostly used on the castings as apposed to the sheet metal. The mag was an option , my '50 B has one , it was original equipment option. I believe either you or 2 cyl. got a digit wrong. When people converted to gas only , they aren't going to convert hood and all. Heck , they wouldnt even take the hood off to change mufflers , they would mutilate the opening first. Does it have original style "clutch head" bolts holding the sheet metal on? I'd say you have a gas only. Wasn't much reason to order an all fuel in 1951.
Kurt_JDB
01-28-2007 13:39:39
 Re: Do I have a multifuel B? in reply to B-maniac, 01-28-2007 11:15:41
B-maniac,
I have checked the serial number again, and the certificate from Two-Cylinder and my tractor both match. The sheet metal does not have the original clutch head fasteners.
I am conflicted about this, if it really was an all-fuel, maybe I should go about my restoration with the intention of putting it back to all fuel specs. I wonder how hard it would be to round up the correct parts?
Kurt
