How do you tell which manufacturer made your cab?
Tim in Montana
01-27-2007 16:44:44
I am looking at buying a new foam insulation kit for my 4320. But I need to know if it is a Hiniker, Hinson, or Stolper cab. Is the name of the manufacturer somewhere in the cab that I don't see it? Or do you have to decide by the differences in the window shapes, particularly the rear window? I have noticed that there are other differences also, such as some have a pair of hinges below the rear window, mine doesn't. Some are painted with more yellow on the verticle parts of the cab, others just the roof is yellow. Mine has heat and air if that is something to go by.
Thanks alot, I know I will get some good answers to my question.
Tim in Montana
Gerald J.
01-27-2007 21:04:44
 Re: How do you tell which manufacturer made your c in reply to Tim in Montana, 01-27-2007 16:44:44
My early 4020 parts catalog shows several brands of cabs. Why would the 4320 have used only one brand?
Gerald J.
low budget
01-28-2007 02:50:44
 Re: How do you tell which manufacturer made your c in reply to Gerald J., 01-27-2007 21:04:44
Hinson was the only supplier of factory installed cabs for Deere at the time the 4320 was built. I think Hinson and Stolper both supplied for early 4020s. If the cab was added after the tractor left the factory it could be something else. The factory RollGard in the cab is the clue here.
Glen in TX
01-27-2007 19:35:33
I thought there was a JD tag on roll bar? Also 6030s had a Hinson tag riveted on right side above console by the ash tray. 4320 may have had a sticky decal only that peeled off over time? The JD SM2089 service manual covers AC & heating service on those cabs for 4320,4000,4020,4520,4620,5020,6030,7020, & 7520. You might also find some clues in 4320 parts catalog if the online one shows cab? http://jdparts.deere.com then scroll down to parts catalog.
Mike Aylward
01-27-2007 17:22:34
Tim, all the 4320"s factory cabs were Hinson cabs. If you are not sure yours is a factory cab or not look to see if there is a Roll-Gard in the back. The factory cab has this. Also, in a factory cab only the rear window and the top of the right side window open. Most other brands side windows and often the front window open as well. There are several other things that are different but these will give you a pretty good idea. Hope this helps. Mike
Tim in Montana
01-27-2007 17:37:35
 Re: How do you tell which manufacturer made your c in reply to Mike Aylward, 01-27-2007 17:22:34
OK, mine must be a Hinson, because it has the Roll Guard and the upper part of the forward right window and back window open. Does anyone else have anything to add to knowing which manufacturer made the cab?
Tim in Montana
JDBert
01-29-2007 11:50:39
 Re: How do you tell which manufacturer made your c in reply to Tim in Montana, 01-27-2007 17:37:35
Just a little note- BUT the 4320's had a roll bar that was hollow while the 45/4620's had a solid steel one. If you want to help reduce the sound some in that cab (every little bit helps on these) Drill a hole somewhere in that roll bar and fill the two uprights with sand and cut a old inner tube and wrap the axle where it mounts and tight the bar back up. Also helps to have 2 floor mats in em. Pray you dont ever lose your A/C- those babies get HOT with no air!!!
K&M seats has a nice kit for the Hinson cabs.
msb
01-27-2007 16:52:39
There should be a plate somewhere,maybe on the door jamb frame or above the rear window. I believe the 4320s all had Hinson cabs, but I have been wrong before.
msb
01-27-2007 16:52:30
