Fehr cab interior?
hogman_2002
01-26-2007 21:14:20
I need to replace the interior in our 4960 and was thinking about going with a kit from Fehr cab interiors. They are a good bit cheaper than from Deere. But do they look just like original or are they made from different material?
JMS/MN
01-27-2007 08:20:46
 Re: Fehr cab interior? in reply to hogman_2002, 01-26-2007 21:14:20
Put Fehr in a 4430 some yearts ago. Good material, inch thick foam. Well-cut and fits properly. Helps to remove the seat to give more working room, used wire wheel on a grinder to clean off old glue, etc. Cost about $140 for lower half. Will use them again for the 4240 this spring.
msb
01-27-2007 07:19:58
Fehr makes kits for several other suppliers, I think. They are located clear out in the country in Illinois on a county road.They hire mostly Amish women to do the cutting etc.The whole place is spotless.
8850dave
01-27-2007 05:16:54
Do not buy a kit from anyone but JD or Fehr as these will fit perfectly.
Glen in TX
01-26-2007 21:36:16
No experience with the Fehr kits here yet but there are others to consider also.
fehrcab.com
tractorseats.com (K&M)
cabinsulation.com
