JD 2510 Rock Shaft seals
texbob50
01-26-2007 16:54:13
Can anyone help me. I have a 2510 John Deere with leaking rock shaft seals. My JD book says to install the seals with the rubber seal outward, and the instructions that came with the seal indicate inward. Which is correct?
thanking you in advance for your assistance
johns48jdb
01-26-2007 20:44:52
 Re: JD 2510 Rock Shaft seals in reply to texbob50, 01-26-2007 16:54:13
i've found that not driving a seal in to where is orginally was and leaving it sticking out a little bit, where you can, will make a new place on the shaft for the seal to ride. driving it in to where it was is just asking for the same leak again in no time. doesn't apply to just this application.
Fern(Mi)
01-26-2007 17:28:52
I do believe the lip of the seal faces inward, fill the back side filled with grease to help luricate it while it wears in.
Fernan
Fern(Mi)
01-26-2007 17:33:04
 Re: JD 2510 Rock Shaft seals in reply to Fern(Mi), 01-26-2007 17:28:52
There is a (so called) four part seal available from Applied Technologies. you'll need your inside/outside seal measurements to order. Worked much better for us.
