4010 q's
rustin
01-26-2007 15:48:33
I am looking t buying a 4010 Diesel with a JD 148 loader, cab, turbo, 12 volt & 4200 hours. Overall very good shape & has several hydraulic fittings that are leaking.
I was looking it over today (after reading back posts on the forum on what to look for & be aware of), & run into a question. The back posts advise to look at 6 holes on left side of the block & if there was any indication of oil/coolant, then this means that the seals on the sleeve are about ready to go & usually indicates an overhall in future. The problem is, I couldn't find or see where the 6 holes are. Can you give me advice on where to look closer at or even post a picture. Any other information on what to look for would greatly help me out. They are asking $10,500 for the tractor. Is this a reasonable price.
msb
01-27-2007 07:47:56
 Re: 4010 q's in reply to rustin, 01-26-2007 15:48:33
The weep holes are about 3/16" diamater aand are about 3 inches above the engine side rail.Sometimes they get filled up with crud and are hard to see without trying to dig the crud out.Does the tractor have a ventilator pump towards the front of the left side of the block.That is the quickest way to determine if the engine has been replaced with a newer engine that doesn't have weep holes.If it has been replaced with a newer style engine then that is a definite plus and the price would not be out of line.
Gerald J.
01-26-2007 17:28:31
The turbo isn't Deere factory. Probably M&W or else an engine from a later turbo tractor like a 4320 or 4230...
Leaking hydraulic fittings should stop leaking by being tightened. I think they are all flare or o-ring, though the o-rings could be shot. You don't want to be around hydraulic oil squirting under pressure, it makes unfriendly holes in skin.
Tachometers are often short on hours because of bad cables or the tachometers having been replaced or rolled over zero a time or two. There is no rule for hour meters like there is for automobile odometers and so hour meter inications need to be taken with a block of salt. Check the wear of the pedals and the fan belt pullies. Since its 12 volt it probably has an alternator and that pulley is younger than the tractor, but the water pump pulley and the crankshaft pulley will be worn too. The water pump pulley wears faster than the crankshaft pulley since the water pump turns faster than the crankshaft.
Figure a 148 loader at about $3000, that still is an expensive 4010D. It needs to be perfect to command that price.
The 4010 vintage cab is better at gathering noise and dirt than at keeping them out and isn't structurally strong enough to act as a roll bar so its not much of a benefit.
Gerald J.
DSK
01-26-2007 16:44:16
The "weep holes" are located on the left side of the engine block about 4" under the intake manifold. If they're leaking bad enough to be a concern you won't have any trouble finding them. I have heard of cases where someone has plugged the holes with whatever to keep them from leaking.(tractor jockey trick). It's also possible the block has been replaced with one out of a late 4020 which did not have the weep holes.(69 or newer). As for 4200 Hrs, it's possible but not too many 4010's still have the original hour meter-tachometer. Ask if it works and if it might be original. As for the price, he's probably in the ballpark, but on the high end of the scale. It's hard to say without actually seeing it. Don't fall in love with it and keep looking around. For 10-5 I don't think it will sell overnight.
