70 pony engine
phil stieneker
01-26-2007 12:48:38
Can the drive gear and brake lining be installed without removing the pony engine?
Chuck730DSE
01-26-2007 13:20:44
 Re: 70 pony engine in reply to phil stieneker, 01-26-2007 12:48:38
Phil, not sure if it was a writter's embellishment of an over zealous mechanic but, they also state that you can remove the water pumps from a 720/730 pony motor without pulling the motor itself. I am not saying it cannot be done, I am saying that it was so much easier to pull the pony.
F-I-T
01-26-2007 14:56:53
 Re: 70 pony engine in reply to Chuck730DSE, 01-26-2007 13:20:44
Well, now, that I have done. And it is not fun!
Frank
F-I-T
01-26-2007 13:15:19
Phil:
If you mean the pinion gear, which is mounted on a shaft that protrudes from the transmission, I'm not sure that it can. I'm told that you can remove the transmission with the pony mounted, but I have always found that it is so much easier on your nerves to just pull the pony, and then you can take your time adjusting the clutch and linkage and such. My two cents.
Frank
buickanddeere
01-26-2007 15:19:05
 Re: 70 pony engine in reply to F-I-T, 01-26-2007 13:15:19
When the starting engine is out that's when to add the coil protection circuit.
