2130 loose steering.
chris hanks
01-26-2007 08:27:36
Hey guys,
It seems to me that most older tractors have fairly loose front steering. My 2130's steering functions okay but there seems to be a lot of play in the steering wheel. I have to turn the steering wheel about 1/3 of a complete revolution before anything happens in relation to the wheels responding. No whining or noises noted.
Is there anyway to "tighten" this up? Do I need to replace a pump etc? It really is not a problem at slower speeds but if I get up to mowing speeds etc it can really be a pain.
Any ideas? or is this just the way it is?
chris hanks
02-05-2007 11:43:31
 Re: 2130 loose steering. in reply to chris hanks, 01-26-2007 08:27:36
Also, I checked the bell crank and rods and everything seems pretty tight. Do I need to disconnect something to be sure?
cannonball
01-27-2007 04:52:09
probably your bell crank....
MAY GOD BLESS THE USA
CharlieMc
01-26-2007 12:40:32
I had a similar problem with my JD1530. I even dismantled the steering column and took it down to my John Deere dealer but they could see nothing wrong. They said that it was probably my mechanical linkage but I really couldn't see any play anywhere. As it turned out it was the connection between the power steering unit and the thick linkage arm which is about 8" long that goes down to the steering connecting rod.
There's a little round cover plate on the right side where you can see the connection. I had to carefully watch the head of the bolt that holds the arm on. When I turned the steering wheel I could see the bolt head moving but not the arm until the steering wheel was moved far enough. Then the arm would start moving which would turned the wheels.
If this is what you see you will probably have to replace the arm. I tried to putting shims in which helped at first but I never was able to keep a good fit with the old arm.
Hope this helps. Charlie
chris hanks
01-26-2007 08:40:17
I also noted that the steering wheel rises and falls when turned. Is this normal?
thanks
Tx Jim
01-27-2007 04:52:15
 Re: 2130 loose steering. in reply to chris hanks, 01-26-2007 08:40:17
Steering wheel rising/falling is correct. Look for looseness of tie-rod ends,bellcrank at center of frt axle are known for wear also. Tx Jim
chris hanks
02-05-2007 07:56:21
 Re: 2130 loose steering. in reply to Tx Jim, 01-27-2007 04:52:15
hey tx. Is the steering wheel rising and falling when not cranked normal as well. the same amount of play is in the steering wheel when the tractor is not on as well.
thanks
chris hanks
01-27-2007 21:04:18
Hey guys,
thanks for the advice. Exactly what is the bell crank. I looked on the parts section and they just listed a pin. Ignorance is bliss until it sneeks up and bites you on the arse.
Tonka
06-26-2007 09:51:26
 Re: 2130 loose steering. in reply to chris hanks, 01-27-2007 21:04:18
Howdy - probably got yours solved by now. I have the exact same problem and am trying to fix it. The bellcrank (steering lever) and both sides tie rods and arms were replaced. The drag link is fine. No movement in center lever either. I'm thinking the steering column has something worn so my question is would it be better to replace entire column or try to replace individual parts?
