35 JD D Air Stack
dwdranch
01-25-2007 20:08:24
I purchased a 35 unstyled D that is missing the air stack. It had the tall one on it. I have seen some breakdowns posted in this forum, but no dimensions. Could any of you supply me with the dimensions (pipe diameter, can diameter, pipe length, can heigth, etc.) so I can try to fabricate one? Also, does anyone have an idea if the oil cup on the breather can be replaced by one from another model or have a good source for one? Also, could someone suggest a source for a muffler? By the way I am located in TX. Thanks for your help.
Bob-Wyo
01-27-2007 10:34:12
 Re: 35 JD D Air Stack in reply to dwdranch, 01-25-2007 20:08:24
dwdranch I sent you a email. My 31-36-38 D's all are 39 inches total length, from very top to bottom of flange. Hope this helps.
Bob
Glen in TX
01-25-2007 21:40:18
Can get you some measurements tomorrow if needed. Bob Schreiber has moved to Indianola IA with new phone number 515-961-6196. He makes just the top cannisters or the complete stack assembly also so maybe easier than making your own. See many with styled D stacks but they are different. Good used ones are just getting hard to find now that don't have any rust holes in them. I'm not sure if the oil cups for later styled D fit or not but yours probably is held on with two bolts and wing nuts where the styled D used a band clamp instead. Brazing or JB weld will fix the holes in cup. JD has mufflers and also aftermarket so try kkantiquetractors.com for mufflers. Aftermarket also has just the cast elbow and elbows with straight chrome pipes already welded on too. rosewoodmachine.com has the dual manifolds also that fit Ds 31-53.
dwdranch
01-26-2007 16:30:42
 Re: 35 JD D Air Stack in reply to Glen in TX, 01-25-2007 21:40:18
Thanks Glenn. I would appreciate the measurements if not too much trouble
Glen in TX
01-26-2007 16:38:07
 Re: 35 JD D Air Stack in reply to dwdranch, 01-26-2007 16:30:42
Ahhh that's what I forgot to do today. Got one in back of shop can take a pic of and measure for you tomorrow if I remember lol. Bob has been making the stacks and cannisters for a while now for D and GP and tool boxes too I believe.
