JD 60 pedistal
RHD
01-25-2007 17:58:26
Have a 60, ser 9511 with a broken front pedistal shaft. The previous owner got a replacement shaft, but it is to long(3in), the steering gear hits the top of pedistal housing (p/n A4410R). The p/n on the new roll-a-matic is A3470R. These are the only p/n I have, the shaft has no p/n. Can someone help me determine how long the new shaft needs to be? To add to the problem, a salvage shop pulled a shaft out of a 60 pedistal(A4410R), it measures the same as the one I have. What am I not understanding?
Blksmok
01-26-2007 10:54:52
 Re: JD 60 pedestal in reply to RHD, 01-25-2007 17:58:26
RHD...I'm assuming you have a "non-split" pedestal (??) If so, the steering spindle (vertical shaft)is different for a ROM front and a non-ROM front. The ROM front p/n is AA3504R and the non-ROM p/n is AA3869R. There should be a p/s somewhere (?) on the spindle.
F-I-T
01-26-2007 09:51:01
 Re: JD 60 pedistal in reply to RHD, 01-25-2007 17:58:26
Are you certain that the shaft is inserted completely into the Roll-A-Matic knuckle? i.e. both rivet holes lined up, not just the bottom hole with the top rivet bore.
That's about the only place that I can see that would make the shaft effectively too long.....
Wish I could offer more.
