B cylinder head casting number
xxx41johndeereBxxx
01-25-2007 17:13:30
I have a 41' B with a casting number B1784R. I am wondering if this is the correct head? I've looked everywhere but found nothing. I think it might be a head off a 47'-52' cause the intake/exaust manifold looks differnt than any others I look at.My elbow to the air cleaner barely fits also. If this head is from a bigger B is it an upgrade or am I losing compression? The tractor runs but dosn't pull much so I put new rings in it and was curious about the head. If you have any info let me know.Thanks.
Ken Thies
01-26-2007 08:42:54
 Re: B cylinder head casting number in reply to xxx41johndeereBxxx, 01-25-2007 17:13:30
May be you need to check the cam.
Could be worn or out of time?
Just a thought.
Ken
PS Thanks Mike.
xxx41johndeereBxxx
01-26-2007 07:32:44
The tractor still runs the same with the new rings. I ran it for about 18 hrs. and still dosnt even get in 5th gear with out falling on its face. It also back fires through the carb so I thought I would get a valve job done but I was wondering if it was even the right head. the tractor ran this way when I bought it. I took the governor off and the timing was off a notch. fixed that and it ran like a B but had no guts. So now I thinking the fly weights in the governor could be stuck or loose. The tractor has a NEW magneto with hot spark. I"m considering a over bore as well. Thanx
Ken Thies
01-26-2007 06:41:36
Ok since you are talking B heads.
Will any of the later heads work on the US Bs?
Ken T
Mike M
01-26-2007 07:18:18
 Re: B cylinder head casting number in reply to Ken Thies, 01-26-2007 06:41:36
No; I think the bolt pattern is different on the older ones.
Mike M
01-26-2007 04:44:38
There are 3 different casting numbers used on B's from 1941-1952 and they will all interchange. Only difference is one of the last ones uses a different shaped washer over the center stud for the oil feed to the rockers. If you still have all-fuel pistons in your tractor it will be a dog ! Deere made gas pistons for those with the 4 1/2" bore 1941-1946 and these will really wake one up. Or some have been known to overbore up to the late B 4 11/16" pistons and seem to worked out ok. You can also put a late B cam in as the lift is different.
Will P
01-26-2007 21:23:49
 Re: B cylinder head casting number in reply to Mike M, 01-26-2007 04:44:38
A dog??? My 1943 B with .045 over cast iron all-fuel pistons, all-fuel manifold and carb, pulls 2-14" with no problem. What it was rated for. Sounds like he has other problems than all-fuel pistons. She wasn't made to have 30 hp. Mine has been dynoed and has 22 hp. If she isn't enough, I get out the 1951 G with M&W's. LOL!!
Will P
greenmech
01-25-2007 20:01:37
I would say you have the correct head,according to the parts book. Maybe the manifold was changed.How does it run with new rings?. Ron Mn.
