4020 scvs
nickg
01-25-2007 13:22:39
I have a 67 4020. It only has 1 remote I would like to have 2 remotes. Thought about buying a control valve for 2 outlets then buying another outlet for the back. Any other things I could do?
Gerald J.
01-25-2007 16:07:59
 Re: 4020 scvs in reply to nickg, 01-25-2007 13:22:39
There are several options and all have been posted here in the last week or ten days.
Gerald J.
G/MAN
01-25-2007 13:31:02
Buy a single-lever closed-center control valve and mount it somewhere handy (the fender works nice or you could build a bracket of some kind to mount it somewhere else) with the supply oil coming from a T-fitting in the pressure line circuit on the RH side of the tractor. You can return the oil to the hydraulic filter housing - Deere makes a special cover to do that or the stock cover can be modified. Do the same thing with an electric Fasse valve.
