2155 won't throttle up
Maryland Line
01-25-2007 12:41:16
I just got a 2155 about 200 hours ago. Knowing little about diesels, I need to ask you fellers what's up with this thing.
There's 5200 hours on it. I started it up yesterday and it had virtually no horsepower to work the loader. I kept killing it if I tried to move it anywhere. The only way I could keep it running was to hold the throttle wide open, but it was only running 1000 rpms. It idles rough, too. It's got to be a fuel problem. Acts like it can't get fuel or something.
What do I do first?
df
01-26-2007 17:59:55
 Re: 2155 won't throttle up in reply to Maryland Line, 01-25-2007 12:41:16
Please don't take this as I am saying you don't know how to run a tractor but, I have 2755 that the fuel shutoff arm on the inj. pump is hard to push back to the run poition (lever towards the front). I have to manually (sp.) push the lever back. It is just tight enough so that the fuel shut off cable will not push it back. If this lever is not all the way to the front of the tractor it will restrict the fuel flow just enought to make your tractor feel like it has not power or RPM's. Hope this helps.
Mike M
01-25-2007 12:55:42
Change the fuel filter and bleed out the air if it's above freezing drain off any water from the bottom of the fuel tank. It should have a drain clear up under the front end casting. This is the first step. Check you air filter too.
