4020 rpm control
Alan in KS
01-25-2007 10:30:22
I have a 1965 4020 diesel synchro that every so often will increase engine rpm on its own. I start the engine with the hand throttle in the start position, giving about 800+ rpm, and then sometimes the engine will start to speed up on its own to 2500+ rpm. I have tried blipping the foot throttle, with no effect, and the only way I have found to get the rpm down is to move the hand throttle to the off position, and then bring it back up slightly. I thought there might be a stuck linkage somewhere but haven"t found one. It does not do this every time I start the tractor, but might operate normally for ten of 15 minutes before this happens. ANybody have an idea what is going on?
Cheers - Alan
Alan in KS
01-26-2007 05:45:40
 Re: 4020 rpm control in reply to Alan in KS, 01-25-2007 10:30:22
Thanks a bunch for the help, guys. One of my big fears has been not being able to get the rpm down and blow the motor. I appreciate the pump shop address, and I"ll use them if I can"t get something local.
Cheers - Alan
Joshua Ratliff
01-25-2007 18:15:06
I'd say it was definitely the governor. I have a 64 model and you can bank on taking the pump off and rebuilding the governor in there every 5 years. other than that I have no complaint in the world with that old girl
DSK
01-25-2007 16:13:47
I'd get that pump off and checked out ASAP before the tractor runs wild and grenades itself. The governors on these Roosa-Master pumps are their most troublesome area. I've dealt with Central Fuel Injection service in Estherville Iowa, good people and were reasonably priced. They likely would have a rebuilt pump in stock for your 4020, or rebuid yours if you like. 712-362-4200. www.centralfuel.com
Mike M
01-25-2007 10:36:23
I'm thinking that is a sign of the internal pumps governor weight retainer going bad. Know any good cheap pump shops ?
