Hydraulic pump leak
Randy G.
01-24-2007 17:27:50
Can a stop leak type product be added to the hydraulic system like the type for the crankcase? I have a leak on my 2510 near the pump and was wondering if such a product existed and where to get it. Want to try something before a complete tear down. Thanks, Randy G.
G/MAN
01-25-2007 07:49:24
 Re: Hydraulic pump leak in reply to Randy G., 01-24-2007 17:27:50
No, stop-leak won't work with fluid at 2000+ psi. Find the leak and fix it properly before it gets much worse. The ideal fix would be to remove the pump and go clear through it, but the leak might be a simple one to fix. I've replaced leaking piston plug seals without removing the whole pump when I was able to access them. Same with input seals, but if the inner quad-ring is leaking, the seal drain line can't let the oil out fast enough and it will blow the outer seal again in no time. Clean the pump area good, try to pinpoint the leak and then determine what needs to be done.
Bob
01-24-2007 18:28:59
There's a LOT of places those pumps can leak, the shaft seal, the piston plugs, the seal "weep line", or even the PS "motor" or it's return line.
Here's my son, replacing the piston plug "O" rings on a 3020...
Third Party Image
FRANCIS PAWELEK
01-24-2007 18:19:33
the only way is like the old 4010,pull the front axle,then replace the 2.00 o ring seal inside the i.d. of the pump housing,unless you can get it without pulling the front end,or tie a bucket underneath and recycle fluid
Roy Suomi
01-24-2007 17:34:14
Nope...Fix it and get it over with..
