Bob, always hard to really tell the damage or degree of wear even standing next to some of them. The diesel will slobber for a number of reasons. Needs a valve job (fuel not burning totally), has a blow by in the head gasket (a little antifreeze or oil going through the combustion process), dirty, worn, or partially clogged injectors (they do not spray a good pattern and some diesel does not burn up) not enough fuel pressure (worn out pumps), injector timing not set correctly, decompression lever not closing properly causing poor compression. The pressure is in three stages on these. It is gravity flow from the tank to the fuel pump. The fuel pump should take it to around 25 PSI, that is enough to get it through both fuel filters and keep a supply to the injector pumps. The injector pump raise a charge of fuel to around 2,600 PSI. That is what it takes to "crack" the injectors, other wise known as how the fuel will go one way, but no compression is lost back through the injectors. The service manual has all of this information, and it has a better memory than I do. It is a gamble unless you open her up, but i would think if it has been sitting around, not run up to op temps, it could just be dirty injector nozzles. There are other issues that could be present, but if it runs, does not knock or make funny noises, a few things have to be close to being right.
