3 point hitch for 730 diesel
DJR
01-22-2007 20:35:01
Can anyone recommend a supplier for a 3 point hitch for a 730 diesel? The ones listed on this site only go up to a 630 and I am looking a reasonably priced 3 point for occasional use. It does not need to be original Deere. Any suggestions would be appreciated. Thanks!
wilamayb
01-23-2007 21:10:58
 Re: 3 point hitch for 730 diesel in reply to DJR, 01-22-2007 20:35:01
Just gonna try to help clear up the confusion.
The 520-630 can share rockshaft arms.
The 620-730 can share elephant ears.
620 elephant ears wont fit a 520 (drawbar frame smaller on the 520-530 series)
620 rockshaft arms wont fit a 720 (different size rockshaft)
MSD
01-24-2007 20:52:16
 Re: 3 point hitch for 730 diesel in reply to wilamayb, 01-23-2007 21:10:58
Your wrong on the elephant ears. 520-530-620-630 are the same, part # AA6610R. 720-730 use part #AF2793R. Rockshaft arms for 520-530-620-630 use part #AA6861R. 720-730 use part #AF 3341R. Standards use a different # for the rock shaft arms.
MSD
01-23-2007 15:43:18
All the parts are the same except for the elephant ears.
Carl NY
01-23-2007 16:08:24
 Re: 3 point hitch for 730 diesel in reply to MSD, 01-23-2007 15:43:18
MSD -- The elephant ears and the rockshaft arms are different. 520, 530, 620, 630 are interchangeable. The 720 & 730 are intrechangeable
MSD
01-24-2007 21:00:35
 Re: 3 point hitch for 730 diesel in reply to Carl NY, 01-23-2007 16:08:24
My mistake, I forgot about the rockshaft arms.
J cook/iowa
01-23-2007 12:24:57
It's news to me if a 3ph, aftermarket or original, for 630 is not identical with the same parts on a 730. perhaps the "elephant ears" are different, but the lower links, lift arms, and toplink look the same to me!
Glen in TX
01-23-2007 13:19:20
 Re: 3 point hitch for 730 diesel in reply to J cook/iowa, 01-23-2007 12:24:57
Yes, the new aftermarket sway blocks are same for 520 to 730 as are lift arm leveling screws. Lift arms I'm not sure about but probably the same also and those off some later new generation tractors will work as well with the telescoping arms. Some of the rockshaft arms may be different too if he doesn't have those.
Glen in TX
01-22-2007 22:56:08
They may can order those too? Did you ask them? Reproduction hitch parts are also available from several suppliers. Plans to build your own also. hoxeyhitch.com
saginawcountytractor.com
