Fighting a Stuck Pinion Gear
txasylum
01-22-2007 07:04:06
I have been fighting with this stuck pinion gear for several weeks now. It is on my rear tire. I don't want to heat it, so I have been soaking it and using an impact wrench, box-end wrench, and muscle to try to break it. Nothing yet. This is turning into a real problem...
Bob
buickanddeere
01-23-2007 20:00:27
 Re: Fighting a Stuck Pinion Gear in reply to txasylum, 01-22-2007 07:04:06
We just loosened off the wedges and the cast center can be bumped along over the stuck pinion gear. When the cast enter is on the ground you can get at the pinion directly and soak/heat/pound the little fink.
Mike M
01-22-2007 07:22:39
I have driven some out with a large punch I made. I used a large piece of round stock 1" or so ? and it is long enough to stick out past the edge of the casting so you can get a good hit on it. I machined the end down to fit up inside the casting. Try this and see if you can get it's attention.
txasylum
01-22-2007 07:25:45
 Re: Fighting a Stuck Pinion Gear in reply to Mike M, 01-22-2007 07:22:39
So the gear on the shaft should slide off as you punch it out?
Mike M
01-22-2007 09:45:35
 Re: Fighting a Stuck Pinion Gear in reply to txasylum, 01-22-2007 07:25:45
Yes it will. If it moves at all ? That's the way it is put together. It has key ways in the shaft and the gear has keys made in it. It should be able to move back and forth some before the gear gets to the edge where it can start coming off.
